Thread: WTB: single Nadella drive shaft
    I need a single Nadella drive shaft.
    Michael
    Michael Moenstermann
    Osnabrueck - Germany
    Early 911S member #1052
    'While accelerating the tears of emotion have to flow off horizontally to the ears.'
    'Understeer is when you see the tree you are hitting, if you only hear the tree then it was oversteer'.
    'You can't treat a car like a human being - a car needs love'. (all Walter Röhrl)
    I have one.Please PM me for photos and price. Frankie.
    Dec 2003
    West Los Angeles
    I have one modified with telescoping ability. PM if interested and I'll give you a 'good guy' price.
    http://www.thesamba.com/vw/classifie...php?id=1881493
    techweenie.com
    Hello Michael I have 3 axles. Email sent. Thanks George
    Dec 2013
    San Gabriel, CA
    Hi Michael,
    i believe i found what you are looking for, check out the link below. hopefully it is what you are in search for. good luck,
    http://www.carrerapartsonline.com/st...232787%29.html
    Aug 2009
    SF Bay Area
    I've got one that you can actually put in your car and use. Not some useless, grossly over priced , piece of broken crap.
    This one has had the outer U joint replaced with a modern one that can be serviced. The inner U joint assy is in very good condition.
    Squirt it with some rattlecan black paint and it will look and perform like a new one. $500.00
    Jim
