Thread: Solenoid on back of MFI pump dripping oil
    Another 911 Driver wicks's Avatar
    Aug 2015
    West Hollywood, CA
    Post Solenoid on back of MFI pump dripping oil
    Do I need to replace it to stop it leaking? Can't find it searching all the parts sources with various keywords, so beginning to wonder...
    1973 911s / 1994 964 Turbo / 1997 993c2
    Call Pacific Fuel Injection in South San Francisco.
    Is it leaking where it meets the pump? There is probably a seal there.
    Can you post a pic of where the leak is?
    Aug 2015
    West Hollywood, CA
    It is leaking around the back of the solenoid where the wire connector is, so I think I have to replace it. Will check with PFI, thanks.
    May 2012
    ITALY
    Sealed with epoxy glue years ago, still ok.
