Results 1 to 9 of 9
Thread: Source for this ground steel ribbon cable
    Anyone know of a source for this style of cable. I've tried EagleDay & other local electrical outlets but they will supply in 12" lengths or 20' spools - neither of which are realistic options for me. This cable is part of the engine bay harness. A good portion of my existing cable is damaged beyond any re-use.
    Thanks & Cheers
    JB
    Success is not final, failure is not fatal: it is the courage to continue that counts. - Winston Churchill
    Early 911S Registry Member #3749
    Call EASY, I'll bet they have hundreds.
    Jan 2011
    Sunny Southern France
    THis is probably not steel. But rather tinned copper...
    You can probably find this kind of stuff by the meter with retail electrical suppliers.
    But Jim is probably a good source, and original!
    MCMaster Carr has it.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Nov 2002
    San Dimas, CA
    That looks a lot like EMI shielding or braided ground straps used in aerospace. That might just be the most expensive possible source but you could "upgrade" to silver-plated copper. One source is Glenair.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Thanks Guys
    McMaster-Carr seems hesitant to ship to customers north of the 49th, therefore not much hope for me there. I would like to chase "edmayo's" suggestion of EASY. I am unfamiliar with the acronym, tried a google search & couldn't come up with anything reasonable. Also "Olivier's" suggestion of 'Jim'
    Thanks & Cheers
    JB
    Sep 2006
    San Francisco
    Jeff Jensen
    Try these guys, I found them to be very customer oriented. I purchased their ground strap when I built a harness for my engine...good guys.
    Georgia Copper: http://www.gacopper.com/Braid.html
    Looks like Georgia Copper are the ones. Thanks for your input Gentlemen -much appreciated.
    Cheers
    JB
