Results 1 to 7 of 7
Thread: Fire Extinguisher
    Dec 2011
    Victorville CA
    Fire Extinguisher
    Which way,,,Dry Chem or Clean Agent?
    Nov 2014
    Port Orange, FL
    Quote Originally Posted by Bob Harriman View Post
    Dry chem is highly corrosive! I have seen plated steel go bad after exposure to dry chem. The best stuff (if you can get it) is STILL Halon.
    Nov 2002
    San Dimas, CA
    The ABC dry chemicals are mostly monoammonium phosphate--those are extremely corrosive. The residue is acidic and also melts into a coating.
    BC dry chemical fire extinguishers are sodium bicarbonate or potassium bicarbonate (potassium bicarbonate is also called "Purple K"). These are mildly alkaline and might cause some corrosion but nothing like monoammonium phosphate.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Oct 2010
    Florida
    One thing to consider is the actual use of the extinguisher. Have you ever used an extinguisher in a real fire?
    Our Naples fire department conducts classes in the use of a fire extinguisher. Give your local department a call and see if they do the same. I know you should never open the deck lid if you have a real fire. Shoot the extinguisher into the rear grille. Interesting.
    Richard Newton
    Vintage Gasoline
    I think mine is Halon II or halation. Stay away from dry chemical.
    I also keep a larger CO2 extinguisher in the garage.
    Oct 2011
    The land of fruits and Nuts
    clean agent is exactly what you want. Any powdered extinguisher is nearly impossible to get out of the cracks when it's discharged.
    I've always thought this was a great concept.
    Porsche taste on a Volkswagen budget...
