Results 1 to 2 of 2
Thread: '68 engine bay wiring harness
    Jan 2015
    san juan, PR
    Does anybody have a diagram showing how the wiring harness branches out as it enters the engine bay area? My car has most of it in place but the fuel pump/ignition area has suffered a bit. I have had a hard time getting anything other than the wiring diagram to understand at which locations should any wires come in, how many, where they branch out and where they end.
    Here's what i got and between this sketch and the wiring diagram i have sorted out some issues already but still need to get things back in order. Aside from the fuel pump and the MSD coil, the base, relays etc. are original and in place. The relay above the coil will be removed, as it was used for a now removed Behr A/C system.
    Any diagrams or photos you can share are appreciated, and feel free to comment on my messy wiring sketch.
    Thanks!
    Javier mirandes
    '68 911
    '14 911-50
    I have used this thread as a reference many times
    http://ww.early911sregistry.org/foru...elays-Analyzed
    MBR #2637
    AKA boschdog
    1968 911 Normal Coupe
    Houston, Texas
