Thread: Tools ~ What am I missing?
    Finally getting around to looking at my 68 tool kit and what I need to make it complete. I need the two larger open wrenches, sizes? Are all the SWB wrenches interchangeable?
    MBR #2637
    AKA boschdog
    1968 911 Normal Coupe
    Houston, Texas
    Oct 2009
    Indiana
    i believe that there is a tool kit thread in the tech info part of the forum which you can use as guidance.
    i believe the wrenches were "drop forged steel germany" but there is a difference in the font, so there is some sort of distinction.
    Junior Member
    Jan 2014
    Sebastopol California
    I'm not sure how much difference there is but my 69S (Jan 1969 build) came with the pictured tool kit. There are a total of 5 open end wrenches(8-9,10-11,12-13,14-15 & 17-19). Missing from yours are the pliers,fan belt and bag of miscellaneous fuses. Note that my 69 tool kit has a straight end on the lug bolt wrench for the jack socket.Name:  IMG_1827.jpg
    Ron Cavallo #138
    69S
    Senior Member Peanut's Avatar
    Aug 2012
    Florida
    There are a few differences unfortunately... luckily the 68 kit shown above has a SWB spark plug wrench, but will need pliers, etc. Your drivers should be marked Klein. As mentioned above, do a Google search (which I did for you):
    http://test.early911sregistry.org/fo...s-amp-Contents
    Scott
    1968 911S
    1986 Carrera
    2006 Carrera S
    Nov 2002
    San Dimas, CA
    You can also go to http://www.porsche.com/international...artscatalogue/ and download the early 911 parts catalog.
    The toolkit contents are on the first page.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
