Thread: Rear torsion bar installation on '67 911S
    When preparing to install the rear torsion bars on the '67, I noticed that the splined lengths on either end are different. Does the longer splined end go in or out of the tube?
    Jerry G
    "Confidence is the feeling you
    have before you fully understand
    the situation."
    Oct 2014
    Soquel Ca
    I recently did mine and I don't recall which end had longer splines. But the spline count is different for the inner/outer. The inner has 40 splines while the outer has 44.
    Early 911S Registry Member 3339
    HAH!! That solves the issue. Thanks for the quick reply. How did you figure out the spline count difference? Trial and error?
    Jerry G
    the situation."
    During my second career as a high school teacher I constantly reminded my students that the only dumb question was the one that was not asked. Well, my queston about the torsion bars was pretty dumb when I broke down and tried to fit the bar in the tube. Of course I found out that they only go in one way. Sorry I asked a dumb question.
    Jerry G
    the situation."
    No gold star for you today
    Oct 2014
    Soquel Ca
    Quote Originally Posted by jerryg View Post
    Oh don't worry. By the time you get your ride height at the level you want you will be an "expert" as well. Good luck
