Results 1 to 10 of 10
Thread: NGK spark plug gapping required?
    Pardon what might be a stupid question as I've seen some different answers but is it necessary to gap NGK BP7ES plugs for a 2.2 engine? If so, what gap setting would be ideal for a stock 2.2S engine?
    Thanks!
    1974 MFI Carrera
    1992 Carrera RS
    S Reg #1245
    Depends on your ignition system. 1mm-1.5mm with MSD.
    Thanks John- my car has the standard CDI so I'm guessing it would be different?
    1974 MFI Carrera
    1992 Carrera RS
    S Reg #1245
    Dec 2010
    Southold, NY
    If expending the labor necessary to replace a set of spark plugs I can't imagine skipping the simple step assuring that the gaps are correct.
    I think the reason the OP is asking is that a lot of modern plugs come pre-gapped for convenience. Use 0.028" to 0.032"
    Exactly- thanks very much!
    1974 MFI Carrera
    1992 Carrera RS
    S Reg #1245
    For a copper plug 0.7mm
    platinum 0.55mm
    Oct 2010
    Denmark
    I have the original kettering (no cdi)system on my november 66 911 , is 0.75mm the general advice?
    Lars
    1967 911 Bahama Yellow
    1962 356 TB 6 Slate Grey
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Aug 2011
    New York
    For '66,
    Bosch W250P21 .35mm/.014in
    NGK BR7ES .032mm
    http://www.partcat.com/ngk
    E Sully
    1973.5 911T
    If I'm not mistaken the 250 P21 is the old style platinum, don't think they were out yet in 66. I first recall them being used with the first MFI motors.
