Results 1 to 7 of 7
Thread: What's right? 1965 Engine Cover Grill Rubbers
    Hi Guys,
    Can someone shed some light. On a 65MY car I've seen two kinds of fitment for attaching the engine cover grill to the panel. Some cars seem to have rubber washers for the T bolts and others have strips. Any idea on when this changed? Which came first? Which is correct? The early parts manual I have shows rubber washers?
    I've borrowed a couple of photos from the forum.
    Strips:
    Washers:
    Nobody knows?
    I've seen the rubber strips an early 911 cars but not sure when it started or stopped. Sometimes things aren't so uniform. I have a friend in the Corvette world who was obsessed trying to figure out why some master cylinder guide plates on 63 Z06 cars were riveted on while some had sheet-metal screws. Was one method an indication of a faked car? He contacted GM and actually found a retired line worker. Turns out that he preferred to use rivets, while Joe preferred sheet-metal screws. So who knows?
    John Schiavone
    Connecticut
    Oct 2009
    Indiana
    i believe the earliest parts manuals showed a rubber washer. if my notes are correct, try #901.511.791.20.
    there are commonly differences between karmann-built and porsche-built cars, if that matters.
    good luck.
    Thanks John, that's a great help. Are the indent ridges in the rubber from the amount of time that the grille has been there for?
    Sep 2006
    La Quinta
    David, mine has the original rubber strips, #301111.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
