Results 1 to 8 of 8
Thread: Photo of Wiring for hood & door light switches?
    Oct 2009
    Indiana
    Does anyone have a photo of the correct wire routing for two small areas ...
    the wire leading to the hood light switch (in the passenger side hood hinge)?
    the wires (2) leading to the door switch (both sides)?
    i need to know which holes to look for in the body.
    thanks, as always, in advance.
    ms
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    hope this helps....we are talking about lwb right? swb is a bit different...
    The Netherlands
    Interesting, does the brown door switch wire have black insulation over it?
    Cees
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by fourteenten View Post
    Cees
    yep.........
    Jul 2014
    Long Island NY
    continuing on with the same theme here, Does anybody have any pics of how the rear decklid wiring harness goes up the lid to get to the 2 license plate light fixtures on a 71 LWB.? Any help appreciated there
    Hope this helps you.
    The Netherlands
    And another one, the trunk end of the door switch cables, male or female spade?
    Cheers,
    Cees
