Will someone please reference a thread on removing and replacing the inserts for the Koni front struts on swb 911.
Thanks in advance.
Thanks in advance.
Jerry G
"Confidence is the feeling you
have before you fully understand
the situation."
Someone must have done this. Any assistance is appreciated before I damage something (usually myself).
Jerry G
the situation."
Pretty straight forward....the posted link helps with the sequence of washers and buffers.
The hard part is generally getting the threaded cap off.....I've seen them butchered with chisels and channel locks. Ideally you need a two pin spanner, fixed span or adjustable, to loosen the cap.
Don't forget to add about 30cc of motor oil to the strut before closing up with the new insert.
Mark Smedley
'59 VW Typ I
'69 911T 2.7
'86 930
'04 GT3
'16 Boxster GTS
Thanks, Mark. Perhaps I'm missing something, but how do I get the old insert out of the strut housing so I can replace it with a new one? I can see a multi-faced piece of metal on the housing that appears to hold the insert in the strut housing. I've attempted to unscrew it, but I haven't yet gotten it to move/rotate. And I don't want to damage anything.
Jerry G
the situation."
The new stut should come with a new nut. A two pin adjustable spanner worked for one of mine, but I had to go hard on the second one with a monkey wrench and a 2' pipe....
I used anti freeze in the strut, as that is what Koni recommended.
As far as new struts go, I can't rate these guys highly enough.
http://www.paragon-products.com/Visi...tore-s/224.htm
Tony
It unscrews from the top of the housing. A big hammer and screwdriver in one of the notches. Make sure the housing is secure in a vice. Really pretty simple as in you will wonder how you didnt see it before, ( at least that's how I felt when I replaced my inserts) Good luck.
Now that I think of it I think used a pipe wrench with a long piece of pipe on the handle for leverage, forget the hammer and screwdriver idea. You still need to secure it in a vice.
Also forgot to mention that its filled with oil that will start spilling out so you might want to have something under it to catch the oil.
Jerry
Is this for the Yellow targa or another car. Should be Boge. No Koni on '67S Targa
Tom
The threaded cap is always VERY tight...especially if they've never been opened. That's why trying to use a chisel on the notches or channel locks seldom does nothing but trash the cap. The two pin spannner....even with an extension like a piece of pipe is the best.
It's just simple threads, but always TIGHT.
Mark Smedley
'59 VW Typ I
'69 911T 2.7
'86 930
'04 GT3
'16 Boxster GTS
