Results 1 to 10 of 11
Thread: Need help With RPM clock.
    Oct 2014
    Europe
    Hi.
    I've got one 123ignition plus big fat spark and my RPM tach do not works.
    Before i put 123 ignition, It works perfectly. Anybody knows if i need a signal converter? Or
    Anything more?
    Thanks for your help!!
    It's in a 1971 911 t.
    in English, tachometer (often called tach; the clock is the device that tells you the time)
    Porsche changed the circuit for the tach right around the time your car was built, so you might need to convert the signals
    if you search this site for "tach" you may find the information you need
    Oct 2014
    Europe
    Quote Originally Posted by 37yrold911 View Post
    Thanks for your note.
    I'll find it.
    Sorry for my english write. ����
    You need a "tach adapt" from Bob Ashlock.
    He's in Spain, so...
    Oct 2014
    Europe
    And the tach adapt, where i buy it? At Bob ashlock or buy in europe? somebody knows a dealer in europe?
    Thanks for your help.
    Oct 2014
    Europe
    Thanks edmayo.
    Oct 2014
    Europe
    Quote Originally Posted by JimmyT View Post
    Muchas gracias jimmy!!!
    Le acabo de enviar mail a Bob Ashlock.
    A ver si consigo solucionarlo.
    Saludos.
    Oct 2014
    Europe
    A few days ago i buyed the tach adapt to Bob ashlock.
    I'll put pics when i install it.
    Thanks for all.
