Thread: Challenge removing nut at the top of a Koni strut.
    Aug 2010
    Colorado
    The nut and shaft of the strut insert turn and I'm not sure how to get it loose. Do I need a special tool of some kind?
    Chris
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    1/2 inch impact wrench.
    Member#2944
    Sep 2007
    San Jose, Ca
    Hi Chris,
    I bought the Harbor Freight cordless 1/2" 18V cordless impact wrench. Painless to remove tires now!
    Usually around $129.99 but there's always a 20% off coupon or sale. I've only had to charge it once after many uses.
    Great tool to have if you don't have a compressor to run air tools.
    Tony
    '68 912 SWT White
    '74 911 Targa Lime Green
    '03 Boxster S
    ‘13 Cayenne GTS
    Senior Member damsroy's Avatar
    Jun 2007
    Connecticut
    An air impact wrench cost $50 At the Home Depot but you need to have a compressor.
    Early 911 S Registry member #3308
    911E 1973 - Brownie- 66k original miles - Second owner
    911E 1971 - gold metallic - sold and missed
    912 1966 - sold
    Junior Member
    Feb 2015
    Stuttgart Germany
    Can't you just use a vise grip to hold the shaft from spinning? Or doesn't an allen key fit into the top of the strut? One of those worked for the konis I took off of my 69.
    Mike Toborg
    1969 912 Soft Targa, 1953 Packard Clipper Delux, 2009 Ford S-max, 1990 Miata
