Lorenzo,
What is the color of this extra sporto wire?
Quote Originally Posted by lorenzom View Post
Assuming you are using the correct era oil temp sensor, this is a direct swap. New oil pressure sensors will plug into the system just fine. BTW, the top 'idiot light' in the right gauge is for your handbrake warning light and is yellow.
Existing wiring harness has three wires into the engine bay for oil: one for temp, one for pressure, and one for oil level.
There is another wire, buried in the harness, that was used for the Sporto oil temp switch (located at the top of the bell housing, on the starter's side of the engine compartment seal) that might be used for an oil pressure 'idiot light' if you desire.
I just did this exchange on my '69 912...
