Thread: 1969 911S Cold Start Solenoid Wire...
    Hi Guys! Putting get final finishing touches and items that are on my checklist to finish off the
    restoration of my '69. One of them is the wire color, of the single wire that goes on top the
    cold start solenoid. Also... in addition to "what color" that wire is, I'm wondering were that wire
    comes from? So, in other words... let's say the wire is grey with red stripe. Once I locate that
    wire... where does that wire lead to? That way I can follow the wire and make sure it is running
    to the correct location on other end of the cold start solenoid. ;o)
    Thanks sooooo much. ;o)
    It's either gray, or gray/white stripe, comes from terminal 87 of the start relay.
    Awesome Ed!! Thanks. Checking it out later this eve. ;o)
    Problem solved!! Thanks. Found the wire hiding behind the CD unit. lol
