Thread: Stupid question about speaker grill
    Sep 2012
    Philadelphia, PA
    What keeps the speaker grill down on a 72 dashboard?
    Serge
    Early S Registry #2457
    Apr 2004
    35,000 ft
    Gravity and little clips in the dash that grab onto the pegs of the speaker grille.
    I believe only 69 has the little clips that hold the grill in. The rest of the years are threaded studs I believe.
    1969 911 E #824
    threaded studs that push into plastic receivers, similar to plastic wall anchors,,,,which I have used !
    Another 911 Driver wicks's Avatar
    Aug 2015
    West Hollywood, CA
    Impossible to remove! Any tips/techniques?
    Manufactured a tool from sheet metal - full leverage, pulling up panel with plenty of force, dash bending up with it...no dice.
    1973 911s / 1994 964 Turbo / 1997 993c2
    The Netherlands
    Guess the previous owner glued to grill onto the dash. Window out, remove the dash ( 7 bolts) and you wll find out what they did.
    Cees
