Results 1 to 10 of 14
Thread: 911 ST project
    Senior Member 993TT's Avatar
    Apr 2013
    Europe
    911 ST project
    I have a 1970 T-model coupe, which I and my mechanic are very eager to start building as a ST replica. Body has e.g. new floors and is pretty much structurally sound, interior will be used for another project. Been "updated" a while ago, so fenders, bumpers, hood, etc. will be replaced anyway. So, I have a few questions for your consideration:
    Which would be the best place to look for fender flares (metal) or complete fenders (glassfibre)? Because of shipping, VAT, customs,.... I would very much prefer an European location.
    I have an "RS-spec" engine, which could be used for this project. How do you feel about it? Would it be enough, or should I start looking for 46 Webers, 906 cams, pistons, cylinders,.... When finished, car would be mostly used on the road with very limited track-day use (possibly some historic events on track and gravel). Any other good options in mind?
    We are currently in the planning process, so any ideas, comments or points to be considered are most wellcome and appreciated.
    Many thanks in advance,
    Timo
    "There's no point living if you can't feel alive"
    - a few 911s & some others
    Early 911S Registry #3206
    Jul 2013
    Scarsdale, NY
    I'm slowly working on one of those as well. Regarding parts, I've just scoured the forums and worked with some of the high quality shops to source parts. I ended up going with steel flares and bumpers, though the hood and rear deck are balsa-reinforced fiberglass.
    As for the engine, I went a bit bigger than the engine used by Flunder (who is a friend and created an amazingly accurate ST). I'm really building more of a hot rod. As such, my car will have a 964 engine, bumped out to a 3.8l with racing P's and C's. It also has 50mm PMOs and a twin plug distributor. The transmission is a G50 with a shortened bellhouse.
    You're going to have great fun with the build and the car--please post pictures along the way!
    Hello,
    we are also considering the build of a 911 ST based on a 1970 chassis.
    From our side we plan to follow the FIA regulation in order to get the "PTH" (French racing agreement) to have the car used at the 'Tour de Corse' rally.
    this means we need to conform the the FIA appendix K/J and the FIA 3025 homologation making as much as possible a "real" werk clone but also getting the best 'legal' and competitive car.
    Since I'm thinking of this build I understood that we mainly can identify 2 type of ST: the pre 72 and the post 72 or the 2.3 and the 2.5L (but it's more complicated than that).
    The main reason is to comply from January 1972 with the evolution of the appendix K/J: this says that we must follow the production spirit for exterior body panel, and windows unless 500 cars were made in period:
    to sum-up from 1972 you must use front steel fender, front and rear steel bumbers, doors, glass wintows... because no production cars was fitted with plastics ones.
    I have identified the following different configuration:
    Chassis 911 ST Pre 1972 group 4 (env 840kg):
    ELEMENTS: DESCRIPTION
    Rear wings: Steel with welded extension up to 1680mm
    Front wings: Plastic up to 1680mm (idem 2.8 RSR)
    Front bumper: Plastic
    Rear bumper: Plastic
    Front hood: Plastic
    Rear deck lid: Aluminum
    Doors : Steel with exterior panel in aluminum
    Windshield: Standard
    Doors windows: Plexiglass
    Rear lateral windows : Plexiglass
    Rear window: Plexiglass
    Gearbox : 911 5 speed with oil pump and cooling radiator
    Engine : 911/20 or 911/22 or 911/21
    Brakes : Standards 2.2S (front S aluminum; rear in cast iron
    Oil cooling: Standard radiator in the front right wing,
    2 radiators in the front wings (L and R similar as the 911R) for cars using injection engine 911/20 et 911/21
    Battery box: No change
    Chassis 911 ST Post 1972 Groupe 4 (env 920kg):
    ELEMENTS : DESCRIPTION
    Rear wings: Steel with welded extensions up to 1680mm
    Front wings: Steel with welded extensions up to 1680mm (idem 2.8 RSR)
    Front bumper: Steel with plastic extensions
    Rear bumper: 3 parts, steel (extensions ??), central part in aluminum (911S ?)
    Front hood: Steel
    Doors : Steel with exterior panel in aluminum (I need to confirm the aluminum exterior panel because it has probably not been fitted on more than 500 cars…)
    Doors windows: Standard
    Rear lateral windows : Standard
    Rear window: Standard
    Gearbox : 915 5 speed with oil pump and cooling radiator
    Engine : 911/70 (911/ 71 depend on sources) or 911/73
    Brakes : Front and rear 917 calipers
    Oil cooling: 2 radiators in the front wings (L and R similar as the 911R)
    Battery box: Deleted for cooling purpose
    911 ST Group 5 (env 790kg - Larrousse):
    Front hood: Plastic
    Rear deck lid: Plastic (like the 911R) (deviation from the 2.3 group 4)
    Doors : Plastic idem 911R (deviation from the 2.3 group 4)
    Gearbox : 915 5 speed with oil pump and cooling radiator (deviation from the 2.3 group 4)
    Engine : 911/73 up to Class limit 2500cc
    Brakes : Front and rear 917 calipers (deviation from the 2.3 group 4)
    Battery box: Deleted for cooling purpose(deviation from the 2.3 group 4)
    Engine Pre-72
    Type 911/20 (engine end of season 1970) 230hp
    Fuel system: Injection High Butterfly diam 41.5
    Piston diameter: 85mm
    crankshaft: 66mm
    Engine capacity (real) : 2247Cc
    Cylinder head: I46E40 I38E38
    Type 911/21 (Engine 1971) 250cv
    Piston diameter: 87.5mm
    crankshaft : 66mm
    Engine capacity (real): 2380Cc
    Type 911/22 (Engine beginning of 1970 season) 230hp
    ELEMENTS DESCRIPTION
    Fuel system: Carburateur weber 46IDA
    crankshaft : 66mm
    Engine capacity (real): 2247Cc
    Cylinder head : I46E40 I38E38
    Engine post 1972:
    Type 911/70 (engine 1972) 275 hp
    Fuel system : Injection High Butterfly diam 41.5
    Piston diameter: 86.7mm
    crankshaft: 70.4mm
    Engine capacity (real): 2492Cc
    Cylinder head : I46E40 I41E41
    Type 911/73 (Rally engine 1972) 275hp
    Piston diameter: 89mm
    crankshaft : 66mm
    Engine capacity (real): 2464Cc
    Cylinder head: I46E40 I41E41
    Sorry for the bad presentation and translation issues, I use to make this as a table in French...
    If you send me your email address I can send you the FIA 3025.
    cheers
    Senior Member majordad's Avatar
    Dec 2012
    Cork , Ireland
    Hello from Ireland ! I too am considering an ST Replica from my 2.4 S shell which I used race. Could you email me the FIA 30125 as well please
    ( whelanporsche@eircom.net)
    Jul 2009
    Bordeaux FRANCE
    Hello from Bordeaux,
    Could you Please send me the FIA 3025 :
    jean-dominique.julia@wanadoo.fr
    Thank you.
    Cheers
    Atlanta, GA
    That is a great comparison list. Not to steer this away from ST's, but would anyone have a similar list showing the RSR specs?
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    I wasn't aware that the 917 brakes were homologated on the 1972 Group 4 cars. Can someone please confirm this?
    1972 911 Narrow-Body Group 4 Project - On The Road.
    Adenda 8/6V of FIA 3025.
    Thank you.
