Results 1 to 10 of 19
Thread: webasto gas heater flex tubes
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    rust red is pending
    flex tubes for webasto gas heater
    this is the early version ...used up to vin 308069
    later cars had the solid tube
    asking 200€ shipped (but +pp fee)for the very solid black one and 150€ for the rust coloured one.
    both come with a new correct 22mm norma clamb.
    May 2011
    Chelsea, Québec
    Any repops coming on these in the future?
    Member #1616
    May 2013
    AUSTRIA (tu felix)
    yes... all components are already in the shelfes---only need to find a few days of time...
    and again--there are at least two different flex tube versions....
    Senior Member pss's Avatar
    May 2014
    Netherlands
    which part is this?
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    964 RS clone (one of many)
    964 Targa original Dutch police car (one of 45)
    964 Turbo 3.6 (one of 1450)
    993 S Vesuvio (one of 250)
    Richard
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by preS View Post
    32
    Richard
    yes but this is the later illustration.
    post#18
    http://smtp.early911sregistry.org/fo...pipe-end/page2
    post#18
    I am aware of that and you also - and I learned it then - pointed out that up to 308069 the flex. was used
    It's great that you make it available again.
    Richard
    May 2014
    Netherlands
    Franz, need some more education I am afraid. As you know I have part 32 (like 49 and 52), and hoped this was for the earlier webasto's (like mine 106-113-1557-1567). The 32's I have however are not flexpipe. Do I need flexpipe or do I have the right ones?
    Txs Jacques
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    Quote Originally Posted by pss View Post
    Txs Jacques
    if your vin <308070 (and around that vin there will probably be some exceptions since they were not completed in seq. order) you will need a flex pipe. Cars w/ a higher number have the fixed one as shown on the illustration. Your 4 vins (presuming they start w 30, 350 or 450) need flex to be correct
    Richard
    May 2014
    Netherlands
    Txs Richard, these were not VIN's but Webasto serial numbers for March resp May 1965 cars.
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
