Thread: Handbrake grip removal
    Junior Member von Zipper's Avatar
    Aug 2014
    The Royal Borough of Greenwich, London, UK
    Hi guys, my 1973 911 I've had since 1978. Not a big deal which is why I've only just got around to thinking about it... I want to replace the plastic (slightly damaged) hand-brake grip and push button with an NOS replacement which has been waiting in the tool box for years.
    Question is, how does the old grip come off, does it clip in place and pull off or is it glued? I was thinking of cutting it off with a Dremel and glueing the new one back on if necessary - Thanks!
    Senior Member NickP's Avatar
    Mar 2006
    Solana Beach, CA
    Heat does the trick, but be careful unless you don't care about destroying it. I used a heat gun till it got warm enough to melt the glue that secures it. Also be aware that the Porsche branded replacement has a pebble texture which differed from the original smooth/glossy finish.
    Nick
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
    Aug 2014
    Thanks for that Nick, so it is glued on too. I have an original glossy NOS replacement luckily. I'm replacing the old hand brake grip because at some time someone had 'branded' the old plastic with the cigar lighter!
    Ridge Restorations Whit's Avatar
    Sep 2005
    Paradise, Ca
    Besides the glue it has an alignment tab on the inside. You will have to wiggle it back and forth off the shaft about 1/2 inch before it clears this tab and you can spin it freely off. If the handle is beyond repair then by all means the Dremel idea will be much simpler. May I suggest you put a new spring in the button mech as well since you are replacing the thumb button. Comes right out when you unscrew the thumb button. Pelican has them for around $15 I think.
    Nice work on the NOS handle. That thing is gold. Good luck!
    Whit
    ridgerestorations@gmail.com
    66' 911 Coupe (Kinda Gone)
    70' 911T Targa (Across the Pond now)
    68' 912 Targa HW(gone but not forgotton)
    67' 912 Coupe (Under construction)
    Aug 2014
    A belated thanks for the info Whit!
