Hi looking for pictures and advice on where to start with installation of loom on bare shell. Sounds like tunnel is the way to go, pulling from front to rear.. Appreciate pictures and advice please.
Rich , Swb 1968 resto
Rich
68 911S
mbr. 2393
I just did this. Is the harness new or rebuilt?
I pulled the tunnel harness from the rear to the front. Then connected the under dash harness to that one.
Same thing with the stater cable....rear to front.
'67 911S
'69 911S
'70 911ST
'73 911T Targa Signal Yellow
'11 Spyder
Early S#1097, R-gruppe #
Start from the middle at the end of the tunnel at the torsion tube.
They are installed from there to the front, then up over the tube to the rear of the car.
The are removed in the reverse of how they were installed - disconnect at the front and back and pull toward center of car.
And because it always needs to be said: NO OEM HARNESS SHOULD EVER HAVE TO BE CUT IN ANY WAY TO REMOVE OR INSTALL!!!
-Marco
TLG Auto: Website
Harness is a new harness from Kroon, had left old harness in the car as metal work was done, it looked 'okay' but had been worked around twisted and tucked to side so much I felt it would've safer to go new.
Probably would have been fine but I don't want to take any chances, having taken a few years to get to this point.
In fact you can see old loom in the bag here when I got car back from spray shop.
Rich
Rich
68 911S
mbr. 2393
Are the turnsignal and wiper controls 68 only or the same for all SWB models?
On re wire I am being ask to source replacements, has anyone seen these anywhere? Or restored their original switches
Thanks rich
Rich
68 911S
mbr. 2393
Rich, those are 64-67 switches, the 68s have a black stalk. They are of course NLA, but it's possible to remove the handles by grinding off the rivet heads, remove the paddles by gently heating with a heat gun, rechrome the handles, bore the black plastic paddle to accomodate the now-enlarged diameter of the handle caused by the plating, and reassemble. While not particularly mechanically complex (compared to, for example, an engine rebuild) it's a time-consuming job that rewards patience.
The new paddles are of a rubber material and not like the originals, so save your money.
AND make careful note of what wires go where. . .it's much easier to reassemble that way. . . if you anticipate taking, I don't know, eight or nine years to restore then photos and a wiring diagram from your own notes are essential.
Looks like some replacement wires are in order as well, that power lead looks worn through. Get yourself an F-type crimper made by Knipex.
Will be replacing some of the wiring here, looks like historically this is where an audio shop lifted power.
Regarding the stalk arms, would you endorse painting these black to match 68 finish?
Thanks Rich
Rich
68 911S
mbr. 2393
Did the 68 have black stalks.? I thought they had chrome..?
https://www.facebook.com/Beltwerks-139610016684496/
S Registry # 1660
Le Belgique ST build.
http://www.ddk-online.com/phpBB2/vie...p?f=28&t=42628
Of course somebody, probably Jim, will prove me wrong. It is OK to be wrong on the Early 911S Registry.
Ok, i am thinking it is Euro delivered cars that had the chrome stalk.
S Registry # 1660
