Thread: looking for Expert!! instrument I found..
    In the first photo I have 2 instrument.
    1. The multi (temp) have a stamp 67 in the back may be a 911 or 912 1967 ??
    2. The KPH is a 356 o 911 EURO??
    The second photo may be a TEMP 911 65-67?
    The last photo may be a 67 911 temp?
    Thanks a lot.
    Nov 2002
    San Dimas, CA
    I'm not expert enough on '67s to identify them but it would help if you could give the diameters,
    I have a feeling your bottom gauge might have been modified by taking part of a gauge from a car with a numbered oil temp gauge (like a pre-67 911 Normal or a '67 911S) and putting it into a simpler gauge for a 912 or maybe a '67 911 Normal. Otherwise the numbers wouldn't be sideways when the "TEM" and "VDO" are vertical.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Senior Member jim amato's Avatar
    Feb 2011
    n.e. ohio
    the one in middle is 67 911 normal & 912
    registry #2072
    Aug 2009
    SF Bay Area
    Quote Originally Posted by trevi1 View Post
    Thanks a lot.
    The spedo is a European (KPH) 356 Spedo. Probably a 63 thru 65. It should have a date stamp or an ink stamp on the back.
    The temp gauge (the 2nd gauge) is a 67 912 or regular 911 temp gauge.
    The 3rd gauge is a mess! It is a 68 or 69 912 Temp gauge with a 66 or 67S Oil pressure gauge inserted where the 912 temp gauge should be.
    Ciao
    Jim
    Thanks Jim!
    Thanks a lot!!!!!!!!!!!!
