Results 1 to 9 of 9
Thread: Brake Hard Line Replacement
    I am planning to replace the brake hard lines on my 73 E during it's restoration as several of them are badly corroded. I have searched all the usual supply places (Stoddard, Pelican, PartsKlassic, Aase, etc) and you cannot buy a complete set of Porsche Original lines. There is a pre-bent aftermarket set made by Uro Parts, but Uro Parts get pretty bad quality scores on Pelican and online in general, although I can't fine any comments specific to their brake lines. The other route is a set of lines made by Cohline that you bend yourself. I cannot find any quality commentary on them, which is a positive. I am concerned about getting the complex shapes right if I bend them myself.
    Does anyone have experience with Cohline or Uro Parts hard lines or any other that they can share?
    thanks, Mark
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Mark,
    I faced the same problem when I restored my car.
    I ended up with a set of Cohline lines and a hand bender. It's not hard, just a little time consuming.
    Take your time when removing the origional lines so their shape is retained.
    Tony
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    Stoddard sell all the individual lines in pre bent configuration. I would go that route instead of aftermarket if you are not comfortable forming your own.
    Mark..
    Aug 2011
    Virginia Beach Va
    PMB sells per bent as well
    Doug Lehman
    Member #2825
    1966 912
    1978 911SC Targa fun in the sun
    Senior Member Per Schroeder's Avatar
    Mar 2013
    Avon Lake, Ohio
    We have pre-bent early 911 / 912 lines and we're getting ready to release the later versions. All are CNC bent, have proper tubing and Cohline fittings.
    Per
    Stoddard
    Per Schroeder
    Oct 2009
    Indiana
    for what it is worth, i have two "go to" sources for brake-related items, in no particular order. i always call paul domitrovic of stoddard. paul works on his own cars, in addition to selling parts, so he has first-hand experience on what works and what is 'close-but-requires-extra-work.'
    the other one is PMB, who has given me very good guidance, as well as selling high quality products.
    hope this helps.
    Thanks for all the help; there are several good choices.
    Per, when do you anticipate Stoddard will have the full set for the 73?
    thanks, Mark
    Aug 2010
    Colorado
    I've used a couple sets from PMB. One in steel and one stainless. Both were close enough and only needed a tweak here and there.
    Chris
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Mar 2013
    Avon Lake, Ohio
    We now have the 69-77 brake line kits available, in green or galvanized.
    http://www.stoddard.com/catalogsearc...lt/?q=sic-355-
    Per Schroeder
