Thread: Unusual perplexing Engine marking
    Doing some research for a friend. We have the engine out of a 67 soft window targa. the car Vin appears correct - 50xxxx, the engine type stamp is correct - 911/06 for a non-S soft window. But the engine S/N is very perplexing. It reads *911912*. The stars and font and all look very correct with no signs of molestation.
    To our knowledge this is the original engine from a car that otherwise looks "normal". The number stamp is on the "back" of the casting rib as would be correct for an early aluminum case, but the numbers????
    Anyone have any thoughts?? Thanks
    Senior Member jim amato's Avatar
    Feb 2011
    n.e. ohio
    I know of a non s 67 targa engine #912031, so I would say it looks good, but need to obtain certificate of authenticity to verify
    registry #2072
    Hmmm...never really considered that it might be correct and just coincidentally odd. I guess I was expecting a 6xxxxxx number.
    Feb 2011
    n.e. ohio
    the S engines began with 96xxxx
    registry #2072
    Feb 2016
    San Clemente, CA
    You will have to pull a COA Please send pics? No, really, what do you want with a 67 Soft window? Please sell it to me
    Good Luck on a very nice car
    Nov 2002
    San Dimas, CA
    Check the thread on the Technical Forum Type 901/xx Engine Build #'s, It includes:
    901/06 911876 8869
    901/02 962026 8895 205
    901/02 962062 8953
    901/06 911920 8965
    901/02 962082 8987
    901/06 911930 8993
    So, 911912 is in this range, 911930's also kind of cool.
    By the way, what's your engine's build number?
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
