Thread: Fuel Gauge Bounces
    Senior Member Bavaria911's Avatar
    Dec 2012
    Fort Meade, MD
    Fuel Gauge Bounces
    On the 1971 Targa, the fuel gauge bounces, but not when the tank is full.
    As the fuel is used in the tank, at around 3/4 full, the neddle begins to bounce.
    Do I have a connection issue, fuel sending unit in the tank issue or gauge issue?
    Thanks for assisting
    Scott
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Carps or Injektion?
    Did you Check allready the tank outlet filter and the tank ventilation?
    Best Regards
    Dirk
    I will bet on fuel sending unit in the tank issue - the tube is wrapped with wire and at some point low on the tube there is a problem with the wire, so the resistance is altered at that point.
    Exploratory surgery is always the gold std.
    Dec 2012
    Fort Meade, MD
    When I bought the car, I cleaned the tank out, replaced the internal tank filter and all rubber fuel lines. Also rebuilt the Bosch fuel pump. When I pulled the fuel sensor unit on the top part of the tank, I was very careful to not damage.
    The car has Weber, 40 IDAs.
    Were it me I'd try another known good sender first, if no change then send out gauge for rebuild.
    Apr 2016
    Stuttgart, Germany
    please measure the resistance of the sensor at low/mid and high tank level and psot your result with and without engine running
    later we will check the gauge with resistors. but the gauge is much more solid than the sensor
    br dirk
