Results 1 to 10 of 14
Thread: Is a partial engine drop necessary to replace oil pressure sender
    Mar 2005
    Is it necessary to partially drop engine to replace
    the oil pressure sender?
    Aug 2009
    SF Bay Area
    Quote Originally Posted by dhopkins View Post
    no, It can be done is a few minutes.
    Jim
    What kind of car do you have? Carbs, MFI, or CIS ?
    Now that I've seen your other post and I see you have a 70 T,,,,then as Jim said,,,NO!
    Mar 2005
    I have tried but failed. I just could not get a good angle on the nut. The nut is directly under a bell shaped housing on the oil pressure sender thus requiring that the wrench be almost flush with the top of the
    engine. Of course, with the wrench so low (even a jointed wrench) that it can't turn bc of the many parts of the top of the engine that are not flush (manifold,carb,etc). Is there a trick to removing the old sender?
    Don
    You just need a crow foot wrench, 6" extension, and ratchet handle,,,,3/8 drive is fine.
    Oct 2010
    Florida
    You may find it works better if you bend an open-end wrench.
    Richard Newton
    What is Stewardship All About?
    Get yourself an el cheapo Heyco BMW toolkit wrench off Ebay and bend the 17mm end up in a vise about two inches back from the end. That will allow you to loosen the sender. For the block it threads into that can be a socket, don't forget new crush washers both aluminum (for adapter fitting) and a copper one between the sender and the adapter fitting.
    Mar 2005
    I live in a apartment building without a workbench
    or a vice. I will have to try the crowsfoot wrench with
    extension. Thanks for the help.
    Don
    1970 triple-black 911T
    2006 Cayman S
    Come now Don, surely you must have done something you regret. . .
    Good luck: With Ed's advice you can't go wrong.
