Results 1 to 10 of 10
Thread: What's this part and upholstery question.
    Jul 2014
    Niagara, Ontario
    Hello, I need some direction, I'm completing the reassembly and came upon a part I have forgotten where it came from, can you tell me what it is used for or where it belongs? It's the silver looking part in the photo and I had it bagged without identifying it.
    The other photo is the carpet piece on the back side of the rear seat, the image shows the carpet piece with the backer / stiffening board exposed. My question... when glued in place should the backer board be facing out as in the photo or not?
    Thanks for the help,
    Mike.
    Metal part goes on the pedal board , its the stop for the clutch pedal. Cardboard goes under the carpet, I think its there to reinforce the carpet where it bends when the seat is upright
    Jul 2014
    Niagara, Ontario
    Thanks Skip, hope your project is coming along.
    Regards,
    Mike
    Senior Member jim amato's Avatar
    Feb 2011
    n.e. ohio
    clutch pedal stop is missing rubber bumper, the rubber gets inserted in between the raised portion on top of stop
    registry #2072
    Hi, the clutch stop rubber is the same as that on the pedal assembly and is available new from Porsche. Not sure how specific you want to be but locking bolts shown are incorrect and should be socket heads and with a locking washer.
    HTH
    Alan
    Jul 2014
    Niagara, Ontario
    Thank-you for your replies Jim and Alan, I will search for the rubber bumper and appropriate bolts and lock washers.
    Regards,
    Mike
    Junior Member
    Dec 2012
    Niagara, Ontario, Canada
    Thanks Skip,
    Mike
    Seems pricey for a bit of rubber but now you know what to look for.
    Nov 2010
    Glen Allan, Ontario
    Quote Originally Posted by CarmelSkip View Post
    Particularly since you can get it direct from a Porsche dealer for under $2, part number I think is 901-423-391-00
    Todd
    1971 911 T Non-Sunroof Coupe
    1984 944 Original Owner
    1989 911 Targa
