Thread: Pre-68 Hella headlight seal...?
    Sep 2009
    UK
    What is the correct rubber seal for the SWB Hella SB19 buckets. ? I understand there are two versions, thin and the later LWB thick seal. I am currently installing the buckets and want to set them at the right depth to receive the correct rubber seal for these SWB lights.
    Thanks, Dave
    Sep 2009
    UK
    Looks like i have the board stumped.
    I don't think Porsche would have had two different specs for headlight bucket depth, I think the problem is incorrect aftermarket seal thicknesses.
    Sep 2009
    UK
    Thanks for the reply Ed. The current offering from Porsche are certainly thicker than the one's i removed. I have the thin version from the VW parts bin so i will see what looks best.
    The ones used on 356 are thinner, maybe also on VW.....
    Stoddard offers three:
    Two versions of thin for 356:
    PCG-631-115-00
    NLA-631-115-00
    One for 911/912
    911.631.115.02
    John Schiavone
    Connecticut
    Sep 2009
    UK
    Thanks John. Didn't the 356 use the Hella SB19 light bucket.?
    Probably explains why i removed the thin seal from my SWB light housings. I will try both and see what one sits better on the wing / fender.
