rare Becker Europa Stereo
produced in 1972 used in MY 73
two blocks !!!! amplifier separat
US Modell
AM AM FM FM FM !!!! triple FM
Stereo works, bulbs new, chrome ok
500€
US Modell
500€
Bump with photos
Becker Europa II Stereo MU J179504
2 Speakerplugs
front and back mounting brakes!
DSC05159.jpgDSC05165.jpgDSC05161.jpgDSC05160.jpgDSC05162.jpgAttachment 376865
Ipod Stereo Adapter also available
bump
Itīs a stereo. Left and right work fine. The stereo lamp is replaced and shows you if the radio station signal you would like to listen to has a good signal and stereo is possible.
Speaker connectors are included. Just insert your cable and screw it with two screens for the left and two for the right speaker cable to the connector. (like terminal strip).
This is a very rare two unit Europe 2 Stereo!!!
The amplifier is in another unit. Back in the very early 70īthe didīt use SMD so there hasnīt been so much space in a Radio to place Stereo and Amplifier into one unit.
Later Becker was able to place stereo amplifier and radio in one unit. But the early stereo Radios in one unit will sound not the good a two unit Radio does!
When I wrote brackets I would like to say mounting points.Mostly they are missing.
You need a mounting point a the backside to connect to the metal part of the dashboard so that the radio is mount properly. (Black screw on the middle of picture 2 and left on pictures 3 and 4.
And you need the clamps on the front, so that the radio faceplate is mounted flush to the trim panel or dashboard (two clamps on the right of picture 3 and 4).
Chrome is Ok but not concour level.
I thought the amplifier was integral on a II. Maybe a I has separate...someone else to confirm?
72 US/Export Europa II (2) Stereo MU http://www.blackforestllc.com/becker/
http://www.blackforestllc.com/becker..._s5/index.html
73 up have 4 FM Buttons
http://www.blackforestllc.com/becker..._s6/index.html
Just curious, is the face plate correct for porsche?
Enzo, please show us your opinion of a correct Becker faceplate for a 72 Porsche
I don't know, that's why I'm asking this
Dirk07.
Just to be clear, does your Becker come with a separate amplifier that is included in your price?
And do you have all the cables/wiring between the stereo and the amplifier?
-Doug
2022 Carrera 4S Oslo Blue
1977 Martini Edition 924
1989 Lancia Delta Integrale 16V
