Thread: Sunroof adjustment questions
    Can't get the back of the roof to lift enough to be aligned with the roof line. It sits 3mm lower
    Here is a picture of the wedge, doesn't seem to be lifting the back of the roof high enough
    I guess I can make my own wedge to lift the back an additional 3 mm but what am I missing? Why can't I get it correct with factory parts?
    Rafik
    The tram fixed to the end of the cable has to move the lift arm attached to that tram, over center to lift the rear of the roof up into position on both sides in sync. What you show in your picture is the stop for the tram. There is no ramp to lift the rear of the roof. Not a job for the faint of heart as premature lifting of the rear of the roof will scratch the sliding roof section. Bad or skipped cable adjustment or too much tension on the sliding section can cause premature lifting. This repair needs to start from the beginning by a pro, DIY'ers need to proceed with caution and care, take it slow. G.Led
    You mean like in the picture below?
    Getting closer but still about 1mm low
    Dec 2003
    West Los Angeles
    What year mechanism is this? I do not recognize that black "ramp" part. The tram/lever mechanism goes all the way to a vertical orientation for the pivoting lever. Whatever that black piece is appears to be stopping the motion...
    techweenie.com
    I can’t believe it’s 4 years and no one has updated sunroof fitment.
    My rear sections does not lift?
    Seems from what I have read the adjustment is with the pivot attachment of the roof itself .
    Does the roof need to come back out to get at these.....don’t see how this can be done with roof in place.
    Or do the attachments to the roof need to be unattached to see the adjustment mechanism ?
    Happy to go at it but wanted to see if others have so key points.
    I will get this fitted properly , no excuses
    Thanks for assistance
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Apr 2011
    N.Calif., south of SF
    Did you get your repaired?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
