Thread: 1970 911S Motor
Threaded View
    Feb 2012
    Mississauga, On
    1970 911S Engine
    1970 911S engine for sale - 6300670. Original MFI.
    Fresh rebuild with 1000 miles on the engine. Professionally rebuilt by well known local Toronto Porsche specialist. All parts disassembled, cleaned, inspected, and replaced as required.
    Crankshaft - micro polished and hard chromed snout.
    Connecting rods rebuilt, re-bushed, and balanced. Shortened fork for ARP rod bolts.
    Align bore and hone engine case with oil bypass mod. Time-sert studs.
    New timing chain and rails.
    Oil pump replaced with 3.0L
    Cylinders bored, honed, chamfered to 86mm with JE forged pistons and rings installed - 9.8/1 CR.
    Cylinder heads completely rebuilt with all new valves, guides, seats, and springs.
    Rebuilt MFI pump (Pacific Fuel Injection) and all injectors cleaned and/or replaced- less than 100 miles on pump.
    Engine tin powder coated.
    The engine is in my car so I can arrange for videos on running. The MFI pump in the pictures was an older temporary pump (out of my E engine) and not the one rebuilt by Gus.
    Motor located in Toronto - 28K USD.
    rannett@dynasoftsolutionsinc.com
