Results 1 to 1 of 1
Thread: '68 (S) engine parts : pistons, rocker arm, intermediate shaft ... and door handles
    Hello
    I have for sale: (parts removed from a 68S engine) - some parts are '1 year only'
    - some '68 (maybe '69?) rocker arm : the non bushed version in very good condition (pad or shaft internal surface) : 25 Eur each
    - rocker arm shaft (very good condition) : 100 Eur / 12pc
    - idle gear : good condition : 10 Eur /each
    - intermediate shaft (0 code) : very good condition with new gear and bearing : 250 Eur
    - 67/68 S piston set in good condition : set of 7! (in this engine there were a special piston (inscription 79.95 on the top!) why? So I added another piston. No noticeable play in ring
    Diameters : 79.93 - 79.91 - 79.92 - 79.93 - 79.93 - 79.91 (and 79.89 for the -0.05 one) : 300 Eur
    new 2.0S set of ring (without the box but new) : 75 Eur
    - flywheel with bronze / copper surface : don't find any reference, so is it an original part? In very good condition, surface seems to be never used : 300 Eur
    - oil pump (early magnesium pump without rib), good condition : 150 Eur
    - Also from the same engine, '68 timing case (and cover) : 300Eur / pair, camshaft holder : 300Eur/pair and valve cover : 150 Eur set of 4 , one S rod : 100 Eur - 'no engine case nor camshaft nor mainshaft'
    - and door handle pair in good condition - no key : 150 Eur
    Worlwide shipping at cost.
    67S+924
