Results 1 to 9 of 9
Thread: Help Adjusting Hood
    Senior Member Bavaria911's Avatar
    Dec 2012
    Fort Meade, MD
    Help Adjusting Hood
    Need assistance. This is the first time taking off the original hood, the rally hood fits similar to the original hood...sit higher in the back.
    I've never adjusted the original hood, but the rally hood really need adjustment.
    How do you adjust the hood brackets to lower the hood to the seal?
    Sorry the photos are upside down.
    Scott
    First, make sure you remove the upper hood latch if you haven't already done so, you can start by adding washers between the forward hood hinge bolts and the hood. Worst case is you get into repositioning the hood hinge mount to inner fender panel. And once you put lights on the hood the struts won't begin to hold the hood up. You'll need the factory racing hood prop.
    Dec 2012
    Fort Meade, MD
    Ed,
    Thanks so much, I followed the instructions and the hood fits nicely...now off to the painter.
    Vr,
    Scott
    Dec 2012
    Fort Meade, MD
    It's been awhile, but I just received the hood back from the painter and plan to mount the hood and lights this weekend.
    I bought the important relay for the fuse box and grommets to protect the wire running through the hood to the relay.
    My question: What gauge wire do I need and the two colors? Would brown and black be correct?
    Scott
    Physics Guy oscillon's Avatar
    Sep 2010
    Washington DC
    I'm just amazed at how well your car sticks to the ceiling of your garage. Amazing grip in those tires!
    ______________________________________________
    Dan B.
    1966 911 black/red
    1966 912 slate grey
    1996 993 black/tan
    Dec 2012
    Fort Meade, MD
    Thanks, I was impressed was the elmers glue too.
    So what about the wire gauge size. Sorry about the photos.
Size:  58.8 KBName:  IMG_0043.jpg
Size:  79.9 KBI used 14 ga. wire, inserted in polyvinyl sleeving. I also used a quick disconnect so that the hood could be removed by just unplugging the harness.
    Dec 2012
    Fort Meade, MD
    Ed,
    Thanks and a great idea with the quick disconnect. I was planning to switch hoods when the occasion called for it, your tip will make that an easy step.
    Vr,
    Scott
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    rotate pictures
    Hope this helps
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
