Thread: Hollow vs solid torsion bars: pros & cons?
    What are pros and cons to hollow vs solid torsion bars?
    "Speed never killed anyone. Suddenly becoming stationary...that's what get's you."
    1973 Austin Mini
    1975 911S 3.2 "the blue goose"
    1973 911E sunroof 3.2
    Hollow are lighter for a given spring rate. If you are limited by available space/packaging then the solid will be a little stiffer than the hollow. Hollow has more stress in the material than solid for a given spring rate but the margin of safety for a Porsche application should be fine either way.
    Besides lighter weight you'll get a better response. Kind of like twisting a empty garden hose vs one charged with water. I have them in my S and had them in my 930 when I owned it.
