Results 1 to 10 of 16
Thread: MFI issue on 1969 911S
    Senior Member lopena's Avatar
    Apr 2003
    New Jersey
    I recently noticed that the oil level in my '69S has been increasing....the level was an inch or two above the "MAX" mark on the dipstick. I suspected gasoline was diluting my oil so I immediately performed an oil change. The outcoming oil was thin and smelled a little like gasoline.
    I then referred to Wayne's book "101 Projects for your 911" which mentioned that fuel dilution of the motor oil is usually caused by a fuel leak deep within the MFI pump. However, I had the MFI pump professionally rebuilt two years ago by an acknowledged specialist, so I'm a little sceptical that a leaking MFI pump is my problem.
    Question: is there something else that might cause diluted oil...maybe running too rich?
    As always, thanks for your help!
    Alan
    New Jersey
    Alan
    N.J.
    1964 E-Type roadster
    1969 911S
    1988 328GTB
    2002 Maranello
    Since you 'recently' noticed this we can assume it had been okay previously. Has anything been done recently that would have caused a change, since the pump doesn't change settings by it self.
    Apr 2003
    New Jersey
    Ed:
    The oil level had been fine previously.
    The car was laid up all winter...I noticed the high oil level when I checked all systems after waking it from its slumber last week.
    BTW: the car runs very strongly...no driving issues whatsoever.
    One other observation...due to the cool weather here (60 degrees), I can't get the oil very hot (temp gauge shows about 170)...in fact, the oil lines to the front cooler are still cool to the touch even after a ten-mile drive. So, if the thermostat to the front cooler stays closed, could that cause a high oil level in the tank? Maybe the oil in the cooler and lines drained back into the tank and is stuck there until the oil gets past 180 degrees?
    Alan
    N.J.
    1969 911S
    1988 328GTB
    2002 Maranello
    That's a very good possibility ! So don't panic yet
    Senior Member boba's Avatar
    Jul 2006
    DFW
    I would defer to Ed on all things MFI. I would question the thermostat allowing oil to flow back into the tank. That would mean that it was stuck partly open and then you would have oil flowing to the cooler when running and your lines to the cooler would be warm.
    65 356SC Dolphin Gray
    66 912 Green
    69 911E Tangerine
    72 911T GP White
    72 911T Aubergine
    72 911T Lilac
    72 911S Black (voodoo)
    90 964C4 Black Targa
    94 964C2 Black Coupe
    08 GT3 Speed Yellow
    Apr 2003
    New Jersey
    Quote Originally Posted by boba View Post
    My theory is that the oil may have flowed back from the cooler into the oil tank slowly (drip by drip) during the winter months while the car was dormant. And since I haven't yet reached a high engine temperature, the oil cooler and lines are currently empty.
    Again, just a theory...
    Alan
    N.J.
    1969 911S
    1988 328GTB
    2002 Maranello
    Fuel from the MFI only gets in to the oil while running. Now that you changed the oil, check the oil for contamination after every run.
    How many quarts of oil did you put in? How did you measure oil level if the engine hasn't reached the temperature required to open the thermostat?
    Apr 2003
    New Jersey
    David:
    I put in 9 quarts, which got me to the middle of the dipstick range after a five mile drive. And, yes, I will do as you suggest...check the oil again after every run.
    Hopefully with the warmer weather this week I'll be able to get that damn thermostat to open.
    Alan
    N.J.
    1969 911S
    1988 328GTB
    2002 Maranello
    Generally the oil drain back that occurs after long non-running periods is from the oil tank draining back into the case past the oil pump gears.
    Longhoods forever! silverc4s's Avatar
    Apr 2003
    Somewhere in Texas
    I would also defer to Ed on any early 911 issue, but I have learned from following Henry' s engine rebuilds at Supertec that he routinely isolates the MFI pump oil from the engine oil, and does not circulate engine oil thru the pump. Not sure how or how often you would need to check the pump oil level, but this would totally eliminate oil contamination thru the pump.
    You could try it temporarily as a test.
    What say you, Ed??
    Bill Conway, Early S Registry member #254
    1970 S, 2.2L Silvermetallic Coupe
    1973 T, 3.2L Black Carrera Targa
    1969 T, 2.4L Silvermetallic Targa
