Thread: 1966 Steering Column Removal
    Junior Member
    Feb 2016
    Bend,OR
    I have searched the Forum, but have not been able to find an answer to this question. I am trying to separate the upper column and clamshell from the lower steering column so that I can remove both for paint. I've removed the actual steering column up to the u-joint where the column leaves the tube for the rack, and I've removed the clamp from the clamshell, as well as the pin. The clamshell will slide to the rear on the column, but only to the point where the diameter of the latter increases. There must be a way to get this thing apart, but I cannot figure it out. This is an early car before locking columns, etc.
    If you have anything that would be of help, my gratitude will be eternal!
    Jerry
    So you separated the top universal joint. You took the clamp off the clamshell to steering tube interface, rotated the clamp and removed the pin. The only thing hanging it up will be the cannon plugs for the switches. They are not large enough to fit through the gap themselves-- they have to be coaxed through one at a time with the clamp rotated out of the way.
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by Jerry Kolb View Post
    Jerry
    took the hole thing of a `64 appart last week.
    no problems at all the clambshell only got stuck a bit when it going over the hole for the lock(i think there is no non hole version)...rotate and pull---and off it came.
