Page 53 of 72 FirstFirst ... 343515253545563 ... LastLast
Results 521 to 530 of 711
Thread: 911S Resurrection Not Restoration
  1. #521
Size:  103.4 KBName:  IMG_20200908_161656.jpg
    do the front part, sanitize and gave it paint by brush. The part of the supports (the most damaged) was also painted, but to maintain it. When the car goes to the drawing shop, this part will be changed (something I don't like but I understand necessary). I put the electricity back on and I am checking the fuses thanks to some advice I received on instagram ... The roof and things in general work but the window I can not lower it. I have checked the fuse box and they told me that it seems that there is a branch to another fuse since it does not have output cables (I think that is the case, but I know little). Does anyone see anything clear? Fuse number 8 is blown.
    I am also working on the deformation that the flare had, now it is less pronounced but I have serious doubts as to whether the shape should be retouched.
    I have better photos of the sheet metal "work", then I upload them!
Size:  101.8 KBName:  IMG_20200629_142944.jpg
Size:  73.5 KBName:  IMG_20200717_214423.jpg
Size:  78.8 KBName:  IMG_20200524_211802.jpg
Size:  184.8 KBName:  5.jpg
Size:  66.1 KBName:  23555069_10155928429073679_1581775655_o.jpg
    is there any original yellow here .....?
  2. #522
    Actual state:
    state should I take it to?:
    control photo:
    the last photo, the shape of the flare. Does it match the shape of the S / T? I'm trying to mimic that shape on the other flare. We have the first photo (the current state) despite having a "round" shape I think it is not faithful to the flare on the other side
    The second photo has been processed with photoshop and is an idea of ​​what I want to do. Than I think it looks more like the right flare. I think I have to slim one area and widen the other a little. What do you think?
    Can someone provide an original S / T photo or not from this same angle?
Size:  76.1 KBName:  IMG_20200908_163419.jpg
Size:  51.3 KBName:  IMG_20200908_163408.jpg
Size:  57.7 KBName:  IMG_20200908_162021.jpg
Size:  65.6 KBName:  IMG_20200911_212329.jpg
    0,5 KG putty
    are they the same way butt flare? Which is more correct? My eyes make me think that in the second image the flare is more highlighted?
    Name:  toad-hall-porsche 72 Nr 16 Sebring.jpg
Size:  86.5 KBName:  72 ST Daytona 73 (2).jpg
    What shape is the roll cage of the second image?
    https://www.early911sregistry.org/fo...mate-ST-thread
    https://www.pieldetoro.net/foro/inde...163307/page-57
  3. #523
    can you hold something in these small holes? I have them on both doors. On top. I open the sunroof and put "a bar" where these marks are. The movable part of the roof stays less than 1cm "from the bar".
Size:  59.6 KBName:  IMG_20200919_220825.jpg
    waiting for the vinyl to get me to repair the headlights ... I'm working on the other bumper. This one has the seams a little different. If you see it in detail, it has one more "small piece" compared to the other bumper.
Size:  109.0 KBName:  IMG_20200920_191030.jpg
Size:  128.1 KBName:  IMG_20200920_191000.jpg
Size:  172.8 KBName:  IMG_20200920_190953.jpg
Size:  112.6 KBName:  IMG_20200920_190943.jpg
    I also have to say that this bumper gave me the impression that tin lead was used to fill the welds! In the upper part when removing paint and putty the welds were not easily seen.
    I also found this on the bumper. I don't know what it could be.
Size:  109.5 KBName:  IMG_20200920_191050.jpg
  4. #524
    They tell me in pelican that the holes in the door frame are to put some rubber stops? They still look like extremely small holes to me but I don't know anything.
    I also attach more photos in detail of the bumper.
Size:  103.1 KBName:  IMG_20200920_191011.jpg
Size:  144.6 KBName:  IMG_20200919_215948.jpg
Size:  104.2 KBName:  IMG_20200919_220110.jpg
Size:  133.6 KBName:  IMG_20200928_205930.jpg
Size:  50.6 KBName:  IMG_20200927_184335.jpg
    30/9/20
    as my sister says, as my grandmother said ...The boss left us ...La Esperanza's phone no longer rings See you at the next point grandpa!Your family loves you. Thank you
Size:  76.7 KBName:  1602583279268.jpg
  5. #525
  6. #526
    Sorry for your grandfather.
    Keep on working, helps with the pain.
  7. #527
    Aug 2017
    el sobrante ca.
    Yes what George said is true..... working helps the pain to be bearable.// the little holes hold a rubber buffer piece that buffers the door window frame when closed.... are you sure the original color for car is not white .... what does the color code tag say... it is in front of driver door on hinge pillar...
  8. #528
    working always helps. He did it when my grandmother left and he has done it (although in a different way) when my other grandfather left. Work is a great ally of the mind.
    And I am very grateful to have a "hobby" like this. Without something to occupy my mind I would be quite distorted but I'm fine.
    Here I continue although it is difficult for one to think that when the project ends, perhaps there is no one around you that you value to congratulate you on it.
    We have all suffered from this disease I guess. Many of us have stolen important moments and one thinks ... I hope that with time the scale of "lost time" balances, although if I think deeply about it I know what the answer is.
    The car is yellow 117. This is commenting at the beginning of the post. The white layer I must understand that it is the primary background. Greetings.
    I've been working the pieces ... plugging pores. "Killing time" .... I have already received the mirror vinyl to try to repair the headlights ... this week I will try to show the result!
    "...Do not loose heart, keep the faith and finish the race."
  9. #529
    "Here I continue although it is difficult for one to think that when the project ends, perhaps there is no one around you that you value to congratulate you on it."
    Don't worry about that. Once that car is on the road again, there will be congratulations.
  10. #530
Size:  92.8 KBName:  IMG_20201007_173200.jpg
Size:  39.7 KBName:  IMG_20201007_173152.jpg
    I've been experimenting with vinyl. The result as a result is good. As aesthetics it is ugly, ugly ..... very ugly. I don't know what I'll do but if I get the tulip I would like to try and see how it looks.
    "Cada uno pinta su propia ventana"
