Took delivery of this mongrel today:
Ford 302 with 5 speed
cool like a sunbeam tiger w/o the big price tag
Early S Junkie # 658
That looks like crazy, scary fun! Pretty car, those TR6's too.
Alan Domme
Austin, TX
'68 912 coupe
'16 VW Golf R
Early 911S Registry #1361
912 Registry
Looks like a very tidy build, well done. If it has not been already done make sure to reinforce the differential mounts. The TR6 will take the V8 torque, but the mounts won't.
I bet she is a ton of fun.
I have owned a TR6 for many years...fun little cars. A small block Ford with aluminum heads, intake, and water pump is supposed to actually weigh less than the stock Triumph inline 6. As mentioned above, I hope some thought was given to reinforcing the rear end including (ESPECIALLY including) the hubs. They are a known failure-point on these cars. I had one fail. At speed it can lead to total loss of control. Look at Richard Good's site, https://www.goodparts.com, for some HD solutions.
Lee Fishpaw
O Gruppe #20
Early S Reg #2175
R Gruppe #714
'70 914-6
'88 911
'85 928S
'74 260Z
'74 TR6
The individual who built this car (Chris Trace) did it right. Here are the specs:
Drivetrain:
- Rebuilt 302 cu. in
- High compression aluminum racing pistons
- Stainless steel valves
- Sanderson headers
- Holley 4 bbl carb -600 cfm
- "Worldclass rebuilt T5 Transmission
- CenterForce dual friction clutch
- Nissan R200 Diff 3.54:1 installed with Richard Good Parts Kit
- Richard Good Parts CV Joint Axle Assemblies
Suspension/Brakes/Wheels:
- Uprated Springs
- SPAX adjustable shocks up front
- Rear coil over conversion and KYB shocks
- Addco front and rear sway bars
- Polyurathane bushings throughout the car
- Toyota 4 pot caliper up front
- Oversized rear brake cylinder
- Stainless steel brake lines
- Uprated front spindles
- Panasport wheels
- Falken ZE912 P215/65-R15
Frame/Body:
- Custom Ratco frame (2-3 times stiffer then original)
- Body stripped to bare metal - 3 coats Dupont Prima Chroma paint
- Newer top in excellent condition with clear windows
Interior:
- Miata seats (with speakers in headrests)
- Alpine stereo/speakers with Kicker Amp
- Red Sequoia dash and matching console
- Pushbutton start, electric retractable antenna
- Aftermarket cruise control
Wow. More fun than a barrel of monkeys, I'd bet.
'66 912 with a 2.2
'62 Lotus Seven S2
'66 Lotus Elan
'63 Karmann Ghia convertible
'76 Alfa Spider
I'd say that qualifies as a nice build!
What a sleeper!!! Very cool!!!
Paul Harrop 12.5% German.
Early S #2059
