Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Weber 40 IDAs, spit, cough, spit...
    Jun 2011
    Mound, Louisiana
    Question Weber 40 IDAs, spit, cough, spit...
    Paul Harrop 12.5% German.
    Early S #2059
    PCaricous Fanaticous G50911's Avatar
    Jul 2014
    SF Bay Area
    figure out what cylinder it is and fatten it up
    1967 911 - #308439
    1971 911 - 3.6 hotrod aka Vader
    1989 911 - Carrera Cabriolet
    Jun 2011
    Mound, Louisiana
    Sounds pretty good now.. I think they need to have the passageways reamed.. JMO... It runs great until it "pops". Then it misses.
    Early S #2059
    Jun 2011
    Mound, Louisiana
    Quote Originally Posted by G50911 View Post
    It would pop and start missing. I would pull out the air balance screw and blow through the passageway with compressed air, then replace the air screw, It would run perfect!!! I am thinking it has some corrosion or debris in the passageways... ????
    Early S #2059
    Trash.
    Check your filter. Pull the sender on your tank and have a look inside. I'll bet it's nasty.
    I reckon you know all about humidity and condensation, eh?
    Early S Registry #235
    rgruppe #111
    Jun 2011
    Mound, Louisiana
    Quote Originally Posted by sithot View Post
    Trash.
    Completely purged the fuel tank with av gas. All new rubber lines, pump, filter, etc. Carbs have been gone through as well. Now it has a dead miss again. Ugh... Fuel drippers!!!
    Early S #2059
    Did you check the idle jet and plug wire for that cylinder?
    Quote Originally Posted by dummkopf View Post
    Never mind.
    Ed is on deck now.
    rgruppe #111
    Nov 2014
    Port Orange, FL
    Check the accelerator pump diaphragms. They are prone to disintegration of the rubber and will leak if they are deteriorated. They will also leak air and cause popping, etc.
    Jun 2011
    Mound, Louisiana
    Thank you!!!
    No on the idle jet. I need to change the plug and see. Wire is fine. Compression is 140# on the afflicted cylinder. 105,000 on the clock.
    Getting a compression tester hose threaded in the plug hole is a challenge. Any advice on that??? I have a brand new OTC!!!
    Early S #2059
