Thread: can I use this Coil ?
    Oct 2010
    Denmark
    Can I use bosch coil 0221 119 021 as a spare for my 911 1967 with stock kettering ignition? ( NO CDI)
    Lars
    1967 911 Bahama Yellow
    1962 356 TB 6 Slate Grey
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    I haven't measured the turns ratio but the resistance should be ok from this Rabbit/Jetta/Scirocco coil. The diameter is wrong and the terminals are wrong but it should be OK electrically.
    I have been using a Bosch "blue" 027 as a "driver" coil you bypass the resistors entirely because the blue has an internal resistor. Seems to work OK.
    Oct 2010
    Denmark
    thank very much, I will then bring it to our roadtrip to spa -Classic from Copenhagen next week
    what would the symptoms be if a coil starts to fail ?
    Lars
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Lars: the symptoms of coil failure are: Stuttering under load, stuttering under high RPM. Then you shut the car off and everything seems fine for a few minutes, then it starts up again. Then the whistling of air through your vent windows and your original factory profile window seals becomes particularly painful and high pitched-- this is the sound of the wind whistling because the motor has shut off. . . Good luck and please print out L57 in color and bring that and a multimeter that does dwell such as the Actron CP 76777 on your road trip-- if you bring it, odds are you won't need it Be safe and have fun.
    Oct 2010
    Denmark
    L57 ?
    Lars
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    http://members.rennlist.org/911pcars/L57.pdf
    Thanks to Sherwood for scanning this many years ago for fair use
