Thread: HELP: Headlight Bucket Mounts: Diameter & Thread Pitch?
    Oct 2009
    Indiana
    I want to tap the threads in the (4) headlight bucket mounts. Two different size taps appear to "fit" but i don't want to wreck the threads, so I'm asking for the wisdom of the community before I move forward...
    My car takes sugar scoops. The parts manual isn't clear (at least to me) about mounting the headlight assembly to the bucket. The PET appears to show part # 900.014.046.02 "pan head screw -- AM -- 4 x 10," mounting the assembly to the bucket. Because of the way the illustration is broken up, I'm just not sure that I am reading it correctly.
    So, can someone confirm that it takes a 4 x 10 fastener? If not, does anyone know the diameter and thread pitch of the fastener that holds the headlight assembly to the bucket?
    And if you have a photo it would be really helpful, too. (Not sure what the Germans mean by "pan head".)
    Thanks for any assistance.
    Pretty sure those are 4 X .70
    912->911 conversion
    Nov 2004
    Calgary, Alberta, Canada
    I'm not sure if it's different in German, but this is a pan head screw (bolt)
    Keith Adams
    Early 911S Registry #906 | PCA member IG: @912R
    1969 Blutorange 912R - 912 to 911 conversion
    1969 Mercedes 280 SE (W111) Coupe
    Apr 2012
    Simi Valley Ca
    Ed is correct, of course. 4 X .70. When you say above that it is 4 X 10, that would imply a 10mm long screw, which seems too short, about 4/10 of an inch.
    BB
    Oct 2009
    Indiana
    i should have expressed my thanks previously. the thread pitch help was really appreciated. (there are some weird angles to those tabs, however.)
    once i tapped the threads, we simply selected the screw that gave us enough length to pass through the assembly and full-depth threads in the bucket-tabs,without much left over. (i didn't measure the length.)
    as always, this community is great at sharing information. thank you.
