Thread: New Hella SB 19-20-21 glass coming soon, back in stock on screws.
    Seattle WA
    Back in stock on the slotted headlight adjustment screws, and phillips attachment screws.
    Attempting to finish this project, a correct version of the Hella SB 19-20-21 headlight glass. This is the last proto that I came by, and we're making one more adjustment. The font is correct, logo is correct (but making a small change), and the lettering is raised on the "outside" of the glass like it should be. Note that I've found 5 different versions of this particular glass and it doesn't have to do with the production number, it's actual changes in other areas. The changes are very small but I was surprised at the number of distinct differences when you get down to some of the minutia.
    Pricing will be under $100 each (hopefully wayyyy under). Early June? Hopefully....
    Thanks for all the support!
    Eric
    Answered prayer.
    Thanks E !
    Ahh and you have done the perfect screws too! I was just winding in an original set and recalling our conversation about the screws being unobtanium.
    Great job Eric! Just when we think the bar can't get higher you raise it again.
    Sep 2012
    Philadelphia, PA
    Eric, would these lenses fit H4 buckets?
    Serge
    Early S Registry #2457
