Results 1 to 2 of 2
Thread: Reattaching door pocket
    Mar 2005
    The door pocket on my 1970 911t has fallen off. The
    two hinges are still on the door. The rivets attaching
    to the pocket have pulled out. How do I fix this? The
    hinge itself is intact.
    Don
    1970 911t
    2006 Cayman S
    Put a thin strip of alum or wood inside the pocket drill holes to match where they pulled out, then put new rivets with washers through both. If the pocket is deformed this gets difficult. Glue felt over your repair piece to camoflage. S
