Thread: Does Anyone Have A Source for the J-Tube Clamps?
    Oct 2009
    Indiana
    I'm looking for the clamps that hold the connecting hose between the J-tube and the headlight bucket. They are similar to the clamps that Stoddard sells (SIC-512-0122-02), except 32mm in size. (The Stoddard clamps are 22 or 23mm). Would prefer new and correct (Norma, I believe.)
    There are several screw-type alternative clamps, but they look cheesy.
    Any suggestions appreciated. Thank you.
    NORMA SCHELLEN is the OEM. NLA in that size. You can give these guys a call. If they are available new, they can get some.
    https://www.belmetric.com/zinc-plate...93moss5cv6vvg1
    Jay
    Oct 2009
    Indiana
    thanks, alex, but wrong clamp. your clamp is for the horn. i need the ones (2 per side) that clamp the hose to the j-tube.
    also, thanks Jsottile. i had already checked with belmetric (and several other sources) before i wrote. no go from them, either.
