Results 1 to 10 of 10
Thread: Fuel pump for 70/71 911T
    Senior Member mar2mar's Avatar
    Feb 2003
    Los Angeles
    For sale, slightly used fuel pump for 70/71 911T. $380 shipped within CONUS.
    Feb 2003
    Los Angeles
    Sorry for the inverted image. Part no for the pump is 911 608 107 01.
    Feb 2003
    Los Angeles
    New low price
    Will buy.PM sent.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Oct 2010
    Denmark
    This is not for a Carburator car....
    1967 911 Bahama Yellow
    1962 356 TB 6 Slate Grey
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    What is your reference? My parts book says it is.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Jul 2014
    Long Island NY
    looks like a carb pump to me
    FWIW Bosch Pump Number should be 0 580 960 009
    Feb 2003
    Los Angeles
    From Grady Clay over at the bird:
    "There are two Bosch electric pumps that appear identical, a low-pressure one for the 911T carburetors and a high-pressure one for 911E and 911S MFI.
    For the 911T carbs:
    Porsche part number – 911.608.107.00
    Bosch part number – 058096 0009
    Operating Pressure – 0.3 bar (4.3 psi)
    Pressure relief valve opens from – 0.2-0.3 bar (2.8-4.3 psi)
    Fuel delivery capacity – 80 liters per hour
    Current draw – 2.5 A @ 12 V
    RPM – approx. 2000 rpm
    For the 911E & 911S MFI:
    Porsche part number – 901.608.105.00
    Bosch part number – 058097 0001
    Operating Pressure – 1.0 bar (14.2 psi)
    Pressure relief valve opens from – approx. 2 bar (28 psi)
    Fuel delivery capacity – 125 liters per hour
    Current draw – 3.5 A @ 12 V
    RPM – approx. 2800 rpm
    The 911T pump pressure relief is the pressure regulating mechanism.
    The 911E&S pump pressure relief is a safety pressure relief.
    The MFI pressure regulation [0.8 ±0.2 bar (11.8 ±0.3 psi)] is done with the return fitting at the fuel console.
    The safety pressure relief partially opens to allow fuel to the filter, exercising the safety while running."
    Feb 2003
    Los Angeles
