Results 1 to 2 of 2
Thread: Center tunnel brake line removal ?
    I have read most of the posts , I have both rubber grommets off at front and rear and also the plastic tie assessable from the rear cover in tunnel. It feels very rigid and agreeable to just pulling out.
    Are there other attachment points ?
    Thanks for assistance
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    I solved it, there are 2 locations with fold over metal tabs and rubber cushion.
    One below the emergency brake (remove to the point that you can swivel to open tab.
    One below the gear shift ( remove to the point to access and open tab.
    Also plastic zip lock on either end of tunnel.
    Striped plastic from wire and wrapped at front end of line behind connector .
    Pulled line from rear after some lube on the lines and cables in tunnel.
    Snagged a bit below the emergency brake as there is a metal pass thru needing another person to gently ease by .
    Came out and will use the wire tie again to the new line and pull from rear to front.
    That will be tomorrow morning.
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
