Thread: Paint Code on Paint tag for 1968 911
    Would anyone know the actual paint code as it would appear on the paint plate for a car originally painted Sand Beige.
    I believe the 1968 paint # was 6807 and colour code 510
    David Withers
    68 912 Sand Beige
    73 911E Sepia Brown
    74 Carrera 2.7 MFI - GP White
    75 Carrera 2.7 MFI Targa - Sahara Beige
    95 Carrera RS - GP White
    02 996 Turbo - Black
    07 997 Turbo - Black
    R Gruppe #449
    Early S Registry #1037
    Aust Typ 901 #113
    Senior Member ThomasTe's Avatar
    Jan 2005
    Denmark, Europe
    Yes, sand beige has code 6807 in 1968. I found these pics of the paint tags for 1968 models (from 912s though):
    Karmann body cars (11825001-):
    Porsche body cars:
    Thomas
    1973 911S Targa
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    the actual code depends on which paint was used (Thomas has shown a Glasurit and Lesonal code above) and also if it was "normal' with a 68 prefix or (i think) high temperature baked with a 97 prefix, and to a certain extend who built it. I think i have only seen the 97 prefix with Lesonal paint but that is only from memory (and a few photos I have looked at today) so that may not be correct. Also it would appear (again from a sample) that the Karmann built cars often had the paint manufacturer suffix left off the number on the badge. I can email you a document with a dozen or more badges on it if you like - also there is an australian delivered sand beige car that i may be able to get a photo of the plate from..
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
    Thanks Thomas, the car is actually a 912 so there are great.
    Hi Hugh, Be good to get a shot of another tag to compare with those from Thomas.
    It was originally a UK car and had been painted Red.
    Existing tag is damaged and hard to read, but it may be easier when I get it off.
    Is it possible that the same colour could come from two manufacturers as the first tag shows 6807 from G which I assume is Glasutit. I recall that for the RS, in most cases they showed only one manufacturer for each colour.
    David Withers
    68 912 Sand Beige
    73 911E Sepia Brown
    R Gruppe #449
    Aust Typ 901 #113
    Dec 2004
    Melbourne Australia
    hi david
    sent you a PM
    yes it is possible to get the same paint number with different manufacturers (and different prefix 68 or 97) as a result
    Hugh Hodges
    73 911E
    Melbourne Australia
    Mbr 3268 Fixer's Avatar
    Jun 2015
    Philadelphia area
    Sand Beige is a great color.
    Matthew J. Mariani BSID, Member 32689
    Haverford Pennsylvania
