Results 1 to 10 of 16
Thread: FS: New Rebuilt 901 Transmission - Allen Johnson
    Senior Member greggearhead's Avatar
    Colorado Springs, CO
    This is from the same car that the engine I am selling came from. The numbers say it is correct for a 1970 911T, whereas the engine number came up a 1971. Just for clarification.
    Anyway, paperwork included - the rebuild, in 2008 cost $2,700. Not including the cost of the transmission. Today, the same core plus rebuild would be much, much higher of course.
    Gears are 11:34, 18:32, 23:28, 27:25 and 29:22, ring and pinion 7:31.
    $5700
    Nice clean trannie, GLWS!
    This is as the stamping suggests, a 911 trannie, not a 901.
    Just trying to help focus potential buyers.
    You might also want to post the alphanumeric gear ratios...is it AFMSX?
    Speedo
    registry# 1283
    Thanks Lars - I have always thought there were 901's, 915s, and G50s - did I completely miss a transmission type all these years?
    I was in a hurry at the end of the day and just using my little 911 tech specs book - I didn't have the gear letters at that point. I'll try to find them today.
    Thanks.
    901s 64-69 pull type
    911s 70-71 push type
    915s 72-85 pull type
    G50 86-? pull type
    registry# 1283
    Banned
    Nov 2004
    Scottsdale, AZ
    Sorry to piss on the parade but technically 70-71 is still a 901.
    Except for diff parts, same internals more or less as chilled cast alum housings. Individual part numbers confirm 901.
    Thanks for the input, guys. I'm always learning.
    Feb 2007
    San Diego
    Yes these 65-71 transmissions are always called 901. The type number does change however from 901/xx to 911/xx on the aluminum to magnesium version. The aluminum case is a called "sand cast" and the mag are called "pressure cast" in the industry. Internal parts are almost identical and interchangeable. Mag weighs a good 10-20 pounds less overall. This trans in this listing is a 225mm "push clutch" which is 70-71 and the 911/01 gear ratios should be A-GA-O-V-ZA. Correct for 70-71 E or S.
    Thanks for the input.
    901/13 is a mag case and there was a 911/01 for a 215mm clutch, I had one from a 69S
    To be accurate, the subject of this ad is a 911 transmission, not a 901.
    It is stamped 911 01. All factory manuals refer to this type as a 911 transmission.
    It does share many parts with the 901, but technically it is not a 901. It was designed for a pull-type clutch release.
    Jon B.
    Vista, CA
