Thread: 2.45E MFI Hot Rod Engine
    Junior Member
    Oct 2012
    Edmonton,Alberta
    The car is sold so I now have a zero mile never run engine for sale. Henry at Supertec built the long block. I will crate and can help with an export broker.
    • 1971 2.2 911E s/n 6210689
    • 86mm bore / 70.4 stroke – 2.45 litre
    • The engine was received in November 2015 and hasn’t been run
    • Fully machined and assembled (long block) by Henry at Supertec in California
    • case savers,oil squirters, oil bypass mod, line bore
    • SC oil pump with flow mod
    • 86mm AA Biral cylinders w/Nikasil coating and JE 9.5:1 pistons
    • 70.4mm crank and rods
    • E cams ground to Mod Solex
    • rebuilt heads by Ollie’s
    • ARP rod bolts
    • rebuilt and tested MFI pump calibrated for 2.45 – MFI Werks
    • Cleaned and tested original injectors – MFI Werks
    • Rebuilt throttle bodies – Parts Klassic
    • new bearings, chains, guides, Wrightwood gaskets
    • Hydraulic chain tensioners
    • Updated rocker arms
    • New oil feed and return hoses
    • New wires, cap and rotor, air filter
    • New hoses and clamps
    • Most hardware and linkage pieces replated or new yellow zinc including air filter housing clamps
    • Heat exchangers blasted and repainted with high heat paint
    • Stock muffler, used
    • Tin repainted
    • Used but serviceable flywheel and clutch
    Pics to follow. I also have dozens of engine build pics and receipts for serious buyers.
    $24,900.00 USD OBO
    Bank wire only
    Junior Member
    Oct 2012
    Edmonton,Alberta
    Pics
    some pics of the engine
    Junior Member
    Oct 2012
    Edmonton,Alberta
    Will also sell as a long block
