Results 1 to 2 of 2
Thread: Help: Headlight ring retainer clip
    Senior Member BlackC4's Avatar
    Apr 2011
    Atlanta, GA
    I've searched this forum as well as the parts books and can't find an answer.
    When I put the headlight assembly back on my '73, there isn't a retainer clip to screw the bolt into, only the piece poking up from the fender inside the headlight bucket. I'm sure that when I removed the headlight there was a retainer clip there but I can't find that part for sale. Did I dream it up? Does the bolt just screw into the tab inside the headlight bucket? If there is a clip, where can I find it? I've searched all of the online retailers.
    Thanks!
    '73.5 911T Coupe Sportomatic Light Yellow (117)
    '73 911T Targa Sportomatic Light Yellow (117) - Sold
    '99 996 Carrera 4 Black - Sold
    The Other Stuff:
    '63 Corvette Split Window
    '67 Datsun 1600
    '88 BMW M3
    '96 BMW M3
    '88 BMW M5
    The tab should be threaded. You can always re thread or weld a nut to the back if that is no longer possible.
