Thread: FS: Duck Tail FACTORY steel frame
    Factory steel frame Duck Tail. Wanted aluminum and found 1 so I will sell this steel framed duck tail. $5,000.00
    '73 or '74?...
    Peter Kane
    '72 911S Targa
    Hello It came off 1974 but you can cut license plate light holes and then you have a 1973. The hole for wire harness is there in all of them. Top picture left side just above mounting holes.
    I thought the 74's had blanking plates where the lights are. Maybe somebody covered them up.
    No same frame just not cut out. You see where the lights should go. I can cut them out and then it would be for the Lemans winning RS driven by Steve McQueen.
    $5,000.00 would go up to $50,000.00 plus shipping.
